I'm sick to pieces of "Orange Software", their modified standby screen. I've sent them this message, I'll post any replies I receive here.
�Orange Software�
My sister recently downloaded a malicious program onto her computer which changed the home page of the browser. It wouldn�t let her change the homepage through the normal menu and there was no way provided to uninstall this malicious software. Thankfully, because it was malicious, a virus checker picked it up and removed it.
Why have Orange added this kind of software to my Nokia 6680?
A different standby screen is pasted over the top of the standard Nokia one, which I don�t need and more importantly don�t want. There isn�t an option provided to disable this �add-on�, why?
I called Orange and was told that tests had shown that users find this piece of software useful and intuitive. I am a user, I find it annoying, counter intuitive, confusing and visually tacky. I�m not alone here, see this google search for �6680 orange homescreen� http://www.google.co.uk/search?q=6680+orange+homescreen&btnG=Search&hl=en&safe=off.
I go into the themes option on my phone and make a change to the �wallpaper�, yet the wallpaper of the standby mode does not change because it�s overridden by Orange Software, is this intuitive? In the �settings� section I change the action of the directional pad in the �Standby Screen� section, however this no longer effects the standby screen, in which way is this intuitive? Making options on a phone ineffective can not be considered �useful� or �easy to use�. It�s confusing.
People have gone as far to develop a �hack� called HSKiller which tries to disable the Orange Software, however it is not reliable. This is mainly because the orange software is coded into the firmware of the device so it can not be simply closed down. Who on earth thought this was a good idea? Are you aware that Microsoft got sued because of similar actions with Internet Explorer?
I want this software removed from my phone promptly and in future versions of �Orange Software� I recommend you add the option to disable it as it�s no different to the types of malware I described in my first paragraph.
I�m in the town of Middlesbrough, I understand that the Carphone Warehouse here have the means to update the firmware on my phone. I suggest you arrange and authorise for them to flash the STANDARD nokia firmware onto my phone, so I can use my phone without the burden of �Orange Software�.
Regards,
Jake.
