PDF Files
4 replies · 2,978 views · Started 29 May 2006
I want to read pdf files on my N80 but the download from adobe (reader symbian version) does not seem to load on my phone.
Does anyone have an answer to this or alternative software which can do this.
Regards
Neil
Hi
Many thanks for the advice, have loaded the software okay.
One further qestion. I managed to look at a pdf file okay but when I tried to open another pdf file it said that the memory was low is there a way round this. Both the program and the files are on the memory card.
Regards
Neil
I've used that PDF viewer and it does have a problem with large files (for example: the First Capital Connect train times). Only solution was to use another PDF app (on a PC) to cut out the pages I needed and create a smaller file.
Slart.
Do you know if the latest firmware release I have seen mentioned would improve the use of memory?
