Someone who has RingtoneStudio
17 replies · 3,183 views · Started 08 December 2002
Yes, there is that option in ringtoneStudio, but operators have usually blocked .mid on their servers. So it still wont work.
Thank you for your replies, guys! Damn! 😞
But... Is there any app for 7650 to convert mid to amr? Would it be possible??
You can use anvilStudio to convert midi to wav and then convert that to amr
www.anvilStudio.com for a free midi editor
A filemanager and videomms needed.Use the filemanager to copy the midi what you wish to send.Paste this in C:/nokia/videos.Rename this copied midi file to nameofmidi.mp4.then open videomms and send the file to whoever you want.When they receive the file they must rename it nameofmidi.mid.They must then paste it into the same file where you originally copied it from. :-?
You can send any file this way as long as the files you wish to send via mms is under 100kb. 😃
[quote="wannyondeathrow"]A filemanager and videomms needed.Use the filemanager to copy the midi what you wish to send.Paste this in C:/nokia/videos.Rename this copied midi file to nameofmidi.mp4.then open videomms and send the file to whoever you want.When they receive the file they must rename it nameofmidi.mid.They must then paste it into the same file where you originally copied it from. :-?
You can send any file this way as long as the files you wish to send via mms is under 100kb. 😃[/quote]
Yeah! 😉
the only program i can find that will allow you to send polygraphis and other files is "efileman.sis"
http://www.psiloc.com/
[quote="JyriK"]You can use anvilStudio to convert midi to wav and then convert that to amr
😃 😃[/quote]
:P Looks good!!! downloading it now... Thanks.
[quote="Nosferatu"]...Looks good!!!...[/quote]
No not really :P but it is the best at the moment.
Hope that someone would make a new one, now that midis are coming back. 😃
[quote="Manowar"]Is there any app for 7650 to convert mid to amr? Would it be possible??[/quote]
MIDI cannot be "converted" to wav. it can be recorded as a wav.
and before you ask, dont even ask if its possible to convert wav to MIDI, as the answer will be a very positive NO 😃
