The phone seems more stable than before, I dont have to restart the phone like I used to do couple time a day. But the only thing still not working is listening to music and surf the net at the same time. The mp3 player would kick out once you log on a website for couple minutes.
Please share your experience after you updated your phone.
Thanks!!!
-N
It is better and seems to keep its charge longer and even keep the signal better.
Browser manages to save my Google mail log in which the previous firmware didn't.
I flashed it to use Tomtom so hopefully it will be worth it.
My phone is vibrating like crazy. I just updated the firmware today to version 4. I took a couple calls today, and after the last call I ended, it started to vibrate like crazy and wouldnt stop till I turned it off.
sTUNNA wrote:My phone is vibrating like crazy. I just updated the firmware today to version 4. I took a couple calls today, and after the last call I ended, it started to vibrate like crazy and wouldnt stop till I turned it off.
Hand it over to your girlfriend, she will like this feature.
Sebhelyesfarku wrote:Hand it over to your girlfriend, she will like this feature.
ROFLMAO...maybe a new marketing technique from Nokia to try get girls to buy smartphones 😊..
So, what does the update cover?
elcaminos wrote:So, what does the update cover?
There is a thread here with a list of bug fixes and updates in the V4 firmware...cant remember which one, just look for threads that mention new firmware and its on the first page somewhere..
fearby wrote:
Browser manages to save my Google mail log in which the previous firmware didn't.😃
Now this is good...this is what I have been waiting for ...saved passwords, was a pain always typing usernames and passwords all the time 😊..
My ears nearly bursed when i held the right soft key for voice command. "dit dur dit" its so loud. BTW go to voice command in tools just open it up then all the voice tags work again, thats what i did
Seems to fix memory card support for my 2gb card (from eBay!). That's the one massive plus for me.
just try a search for "firmware" and you'll find it.
nostarwhere99 wrote:The phone seems more stable than before, I dont have to restart the phone like I used to do couple time a day. But the only thing still not working is listening to music and surf the net at the same time. The mp3 player would kick out once you log on a website for couple minutes.Please share your experience after you updated your phone.
Thanks!!!
-N
Do you select "play in background" option?
Serhat
yer it seemed more stable and faster untill i installed a load of apps and now its slow through the menus. least it dont crash though
lordlothar wrote:Do you select "play in background" option?----------------
Serhat
Thanks for the tip - cool!
