is there any ways to disable the camera shutter sound ?? n70 shutter sound can be disable by turn off the "warning tones". but this trick doesnt work in my n73.
any other ways ??
disable camera shutter sound
If I put my phone into the silent profile, it disables the shutter sound
Jay3gsm wrote:If I put my phone into the silent profile, it disables the shutter sound
Agree. Same way to me.
rickinson wrote:is there any ways to disable the camera shutter sound ?? n70 shutter sound can be disable by turn off the "warning tones". but this trick doesnt work in my n73.
any other ways ??
By editing the profile (whichever one I choose) and turning off "Warning tones" it disables the shutter sound on my N73 (Orange UK).
tried all this tricks, seems not working, the sound is still there.😡
yup..i tried all the same tactics as well... but none worked for me...
Yup ive been having the same problem with my n73. No options allowing you to turn off the camera tones 😞
wajahat_k wrote:Yup ive been having the same problem with my n73. No options allowing you to turn off the camera tones 😞
Just put on Silent Profile.
the disabling of camera sounds are not available on certain product codes(asian ones i think) - european codes should work ok by putting phone on silent.
My nokia was made in finland though. But yes I think it has the ME version because, theres arabic in it as well.
Oh well, one temporary solution i found was putting it on the CAMERA TONE 4. Its the quietest and quickest tone. Hardly noticable
Hope that helps 😊
Hi, you need to update to new version of the firmware.
The newer version allow you to use turn off the warning
tone and then no sound for the camera.
hey guys...i just upgraded my N73ME firmware to the 4.0 series and the camera tone is off when the warning tones are set to off...it works fine..i used the following product code for the upgrade 0539239/0537289
i want to now how can i upgrade my n73 i se (product code for the upgrade 0539239/0537289) what is this ????????
sumanmondal wrote:hey guys...i just upgraded my N73ME firmware to the 4.0 series and the camera tone is off when the warning tones are set to off...it works fine..i used the following product code for the upgrade 0539239/0537289
i want to now what is product code for the upgrade 0539239/0537289 because i don't understand ????? :con?
you need to do some reading, u'l find every answer under the sun here if you look for it the product code is what tells nokia updater which version of a phone you have and its what you have to change if you want to say turn your bog standard phone into the music edition or internet edition.READ UP!
