[quote="CrisS"]okay, it seems that there will not be another communicator for a while so I have to ask. I am a 9210 user and more or less happy with it. I have plently of nice software which is registered under the current IMEI no. I would guess I will loose that if I upgrade to the 9210i (am I right there?)
The main question is how much better is the 9210i and what advantages would I get from it?[/quote]
😉 Well... the Nokia 9210i has actually some improvements over the Nokia 9210...
These are increased memory and some new software...
Memory:
This is the major difference between the two devices since all most all of the others (the software components) can be obtained for free and are are compatiable with the Nokia 9210...
The Nokia 9210's specification for memory is:
Total memory: 24MB
Application memory: 14MB
User memory: 2MB
Execution memory: 8MB (SD-RAM)
16MB Application Card in the sales package
The Nokia 9210i's specification for memory is:
Total memory: 40MB
Application memory: 16MB
User memory: 16 MB (contains 6 MB preinstalled applications)
64MB Memory card available as an accessory
As you can see the main difference is an increase of 14MB in the user memory and the supplied MMC card is 64MB instead of 16MB. There is no extra execution memory (a mistake in many people's opinion...).
9210i also have a new Web Browser (based on Opera):
The new WWW browser offers better compatibility with WWW pages. The main new features are the following: HTML 4.01 (the Nokia 9210 Communicator has HTML 3.2) Support for XHTML 1.1, JavaScript� supported and CSS (Cascade style sheet)
2 windows concept (two windows can be open at the same time), Content sensitive pointer (pointer recognizes the content it is placed on), Edge sensitive scrolling with pointer (you can scroll web pages easily with pointer)
Real Player One has also been added to the Nokia 9210i. The RealOne Player lets you play RealAudio and RealVideo files on your Nokia 9210i Communicator. It supports streaming from the Internet in HSCSD networks and is pre-installed into the device. You can stream from services that use the newest RealNetworks codec RealAudio 7&8 and RealVideo 7&8 (RA7, RA8, RV7, RV8). In addition the service must be available with bit rates suitable for your HSCSD connection. You may find some material that is only designed for wide band Internet access and this kind of material cannot be viewed on the Nokia 9210i Communicator.
A Macromedia Flash player has also been added to the 9210i device. Flash Player supports Macromedia Flash content, which is widely used to deliver motion, sound, and interactivity. This means you can now enjoy Macromedia Flash movies, cartoons, and even games right from your mobile phone. Plus, you'll be able to view engaging presentations, e-learning content, even personal productivity applications that keep you on the move. The Flash Player provides a rich Web experience, in part through the use of Vector graphics that enable sharp scaling.
p/s: if u upgrade to 9210i u can still actually request for the new code... but sometimes u need to give them the "proof of transaction"...
