hello to all, theres a new firmware for the N80. 5.0.719.0.2
i have just up dated my firmware from the rubbish 4.0.707.0.7 to 5.0.719.0.2
the phone works great. i hope on stand by it stays on for 5-7 days like the old firmware, other than that the new firmware is great, and feels very stable.
:icon14: 😊
i cant see anything new, it must be the bug fixes
they have fixed, you can now check your credit again like before firmware, to see how much money you have , on p.a.y.g
v 5.0719.0.2
24-05-2007
rm-92
nokia n80 (01)
I'm sure these updates take longer each time 😊
Anyway, it's good to see that flash message support for things like balance checking is working again. I think the web browser has been updated also. I've just installed my server certificate via the normal browser rather than the Services version and it worked fine (went to the wrong one, but never mind 😊 )
They've not exposed the NAT and STUN settings for Internet Telephony as I'd hoped they might, but it looks very much like this is now a concious design choice on the part of Nokia... however if you've got an incompatable router it now fails much faster (which is actually kinda a good thing)
URGENT HELP
I recharged my phone before I started the update. Started the update and the entire 73.4mb was downloaded. Just when it started updating the phone went dead. Black screen.
A notice came up about PHONE RECOVERY. "Take out battery, replace battery and charger and press the power button for a few second"
None of this is working. The phone will not power on. I GUESS THIS IS THE END OF MY NEW NOKIA N80.
Can anyone help me get power back.
There are a few ways around a dead phone flash, however the only one that's guarenteed is to take it to your local Nokia Service Centre. Any of the dead phone flashing techniques can invalidate your warranty. You can find your nearest Nokia Service Centre via this page (assuming you live in the UK, there are also alternative pages for non-UK residents).
The good news is that NSC repairs for this kind of problem are free, they will also be able to update your phone to the new firmware for you.
Thanks so much for the info. My luck, It just happens that I am in Central America and none of the service center existsm I will have to wait until September when I return to NY to try to get fixed.
Anyway, thanks a million
Please, can anybody check if this new firmware enables N80 A2DP support?
I've heard that the new firmware for N73 does, so, I'll be very happy if this firmware add this support too.
Thanks.
more f/w!!
Im tired of updating... *moan moan grumble*
Thanks for the FYI. I just downloaded and installed the new firmware without any problems.
Anyone know what the new changes were?
please help me...
as usual with any other upgrade I ended up having A LOT of "not installed" applications in my memory card
I *tried* the usual process of manually reinstalling them from the phone application manager BUT this time I am getting "Unable to install" for about half of them... and "Expired certificate" for the other half
what can I do?
At least, is there a simple method of removing those "dead" entries from the phone without breaking everything up?
faquick wrote:please help me...as usual with any other upgrade I ended up having A LOT of "not installed" applications in my memory card
what can I do?
Try setting the date on your phone back to 2006. That's how I install all my programs that have expired certificates.
what can I do?
yep same problem after every update, here is what I did, try to install manually every not installed program and write down the file names (xx.sis) which could not be installed. Then plug phone with mass storage mode and delete those sis files found in memory card. Some of those not installed seems to be expired and some corrupted etc. I cant get it why the phone tries to install those every time phone is booted.
At the end, I decided to go through and reformat both phone and memory card. Now I am collecting again all the most useful programs, this way they will surely be more up-to-date than the old versions I still got 😊
The only thing I forgot to do was manually saving my bookmarks to be able to restore them by hand... 😞 but I will find them somewhere on my PC :P
Do you know what changes nokia have made with this firmware??
Surf
faquick wrote:At the end, I decided to go through and reformat both phone and memory card. Now I am collecting again all the most useful programs, this way they will surely be more up-to-date than the old versions I still got 😊The only thing I forgot to do was manually saving my bookmarks to be able to restore them by hand... 😞 but I will find them somewhere on my PC :P
How do you manually save them? I lost my bookmarks as well.
upgraded fine with nsu, doesnt appear to be any new features, if anybody finds any let me kno ;]
BUG FOUND!
Disable the keys sound (beeps when you type a key). My phone is in portuguese so I don't know how to write this function in english.
Well... keys sounds disable, right?
NO! Put your ears very close to the speaker and type any NUMBER.
There it is! The sound, veeery low, but there it is!
hummm anyone done this on vista??
i dono if i cba to keep testing their phones for free anyore 😡 :icon13:
Yeah, i noticed my kets now make a noise when dialling numbers etc, it's pretty poo! It's the only time it seems to do it though. Also, I think my alarm tone sounds different, i was so confused this morning when my alarm went off. It's similar, just slightly different!
All else seems good so far, just got to reinstall all my apps now, grr!
I don;t mind though, anything to get away from the 4.0707070707 firmware last time, it was awful! Wish I had never bothered upgrading it.
bbracer16valver wrote:hummm anyone done this on vista??
Yes, I did my flash on Vista. Worked fine.
Did my flash on Vista too. That was the third time I did a flash on Vista.
No problems so far.
hummmm its staying of the detecting phone part forever 😡
bbracer - hit cancel and try again. That happened to me at then it worked fine the next time.
erm.
my NSU says i have the latest software availible
and if i go to device manager on the phone too and try to update it says there are no updates.
lol. what now 😃 ?
It depends from region and if your phone is a network locked version.
im in UK and its unbranded 🙄
doovydoo wrote:erm. my NSU says i have the latest software availible
lol. what now 😃 ?
Yes I had that as well the first time. I just closed it and ran it again. Though as has been pointed out by a few other people this update is meant for non-network specfic firmwares.
well truphone isnt working! thats all i can figure out at the moment. if anybody is getting it to work with the new firmware please tell me.
still not working for me
load up NSU decting phone is as far as it gets cancel that then try again no luck, close program down doensnt re-start, re-start PC same as before just decting phone never finds it
PC suite on says N80 found, then says new update available for phone, click that then again nothing
so sod it as i seen no truphone i wont take the risk i can live with V4 for abit
on vista BTW
