Does anyone know how i can stop the phone answering automatically as soon as the slide moves to the up position? I can see myself accidentally answering a lot of calls to people i dont want to speak to while the phone is in my pocket.
Question about the slider - re:calls
To my knowledge you can't.
Ah ok, will keep looking for a program or something if it exists!
There is an option to stop the keypad locking / unlocking when the slider opens and closes Jon, Perhaps that might have an effect on it. Worth a try at least.
Ah really, how does one get to that setting if you don't mind?
Jon_8986 wrote:Ah really, how does one get to that setting if you don't mind?
RTFM 😉
Que?
RTFM = Read The 'eFfing' Manual
Go to Settings > General > Security > Phone and SIM Card and option is in there.
Ah yes, cause I carry that around with me all day at work don't I:con?
Anyway, thanks, will give it a go.
i m not sure but look at anfy call manager
that might help
Cheers chap
Jon_8986 wrote:Does anyone know how i can stop the phone answering automatically as soon as the slide moves to the up position? I can see myself accidentally answering a lot of calls to people i dont want to speak to while the phone is in my pocket.
I can't understand the problem. Are you saying you involuntarily open the slide of the phone thus answering calls? I think you need to sort THAT out before finding a workaround on the phone 😉
It was posted on behalf of someone else so I can't tell you if they actually have this problem a lot or not, its certainly never happened to me but i think he was just looking for a quick fix, if there is one.
