1. Why do companies like Symbian (they're not alone in this, you know) bother issuing time-limited DRM-like certificates for software when they're so trivial to get around?
The real question is why do companies like Symbian require these certificates AT ALL. Why kill off your own developer base? And no, I am not buying into the bogus argument that it is all for my own protection against malware.
2. Why did it take Nokia and Sony Ericsson SO long to realise that computers like RAM and that they were shipping device after device in generation after generation with far too little of the stuff.
As bigger SDRAM does not cost significantly more (until some threshold, at least), I would guess that the reason here is the power consumption.
When was the last time you saw an advert for the pretty decent P1i?
Today, in the lobby of the office building where I work. And it was a pretty big billboard, too.
Yes, I and a few other bloggers complained about the motor noise, but we meant for this to be filtered out in software or reduced mechanically, not FOR THE ONLY REAL UNIQUE FEATURE TO BE REMOVED!
It is not the feature set manufacturer worries about, when making such a decision. The main decisive factor here is the expected number of returns for service. Building a device is relatively cheap in large batches, but servicing it in expensive.
5. Ah yes, interfaces. Why on earth are there four (and arguably five) totally different ways to launch some applications in the Nokia N95?
Puzzled me too, but then I am not in N95's target audience. This is most likely a result of some political play inside Nokia - things like this often cause duplication of functionality (see: Windows).
6. And talking of interfaces, which illegal substance WAS the designer of the Nokia 3650's CIRCULAR keypad smoking? "Woo, round and round we go, I can see it now..."
I actually liked it, after a while. It makes gaming so much easier, as the keys become spread out and easier to press. Plus you can assign the diagonal direction keys easily.
7. Why does it take so long for an Nseries camera to start up?
Nokia makes PHONES, not cameras. I fail to see why so many people here are trying to use it as a camera and then complaining about various things it doesn't do: no optical zoom, slow startup, washed out colors, noise, etc. etc. It is NO camera, however hard Nokia is trying to make you think so.
8. Why was it that, despite OPL being one of THE crown jewels in Psion's treasure store, an onboard language that enabled the creation of THOUSANDS of user-written applications...
Just use Python already, will ya? =)
How come it's OK to spend 10 million dollars on an ad campaign but too risky to spend 10 thousand dollars on an intiative which could potentially do the same for a modern manufacturer as it did for Psion, only on a larger scale?
Given how Psion ended up, I do not think it has been a very good comparison 😊
