Moving Menu icons
10 replies · 4,613 views · Started 04 December 2007
Using the new v20 firmware. Trying to arrange my icons to be user friendly for me in different folders. There seem to be some icons that have what looks like a C in the top right corner where the option to move to different folders doesn't appear. I really don't want Music in my root folder but it seems I have no choice. Any way round this?
the C in the upper corner right indicate that there is a program in use in this folder, to see what is in use press down the menu key a few seconds to have the task manager and see what is running.
regards.
havana7 wrote:the C in the upper corner right indicate that there is a program in use in this folder, to see what is in use press down the menu key a few seconds to have the task manager and see what is running.
regards.
Or go into the folder and the same little thingy will be in the corner of the running app.
I'm just irritated that you can't change folder icons. Or move the "system" folders. Not fair. I want to pick me own icons.
:frown:
THAT is one awesome little hack! I've been trying to do this for ages and it pi$$es me right off not being able to! Thanks for the link.
Hilarious ! 😃
Having to put up with the default arrangement has irked me for years.
Revenge as they say, is a dish best served cold.
MUAHAHAA !
randomfan wrote:You can, there is a little hack that achieves the effect you want. I've just tried it and now I have my Office folder at the root level of the menu 😊
See http://www.fwrnando.com/blog/?p=94
Has anyone tried this successfully on V20. It worked for me on V15 but I can't seem to access Menu fast enough in the latest version. :frown:
rolan73d wrote:Check out my new post...
U can change folder icons due 2 hacking phone.....
Any chance that youould post the full details of your "hack" in this forum please.
[email protected] wrote:Has anyone tried this successfully on V20. It worked for me on V15 but I can't seem to access Menu fast enough in the latest version. :frown:
It also worked on my N95 8GBwith V15,but now with V20 doesn't work...no option to move that folder...😡
