Product Codes for Nokia N85
40 replies · 64,265 views · Started 23 October 2008
Does anybody have a list of product codes for the Nokia N85? I've heard that the FM Transmitter is disabled in the Hong Kong version, which I purchased just the other day.
JohnnyFeet wrote:Does anybody have a list of product codes for the Nokia N85? I've heard that the FM Transmitter is disabled in the Hong Kong version, which I purchased just the other day.
Its too early, NSU doesn't support N85 yet.
Wait a bit till it get supported while am gather list of product codes.
Update here is a list of product codes i manage to found.
APAC
0561352: THAILAND Copper
0561363: BANGLADESH Copper
0561353: CAMBODIA Copper
0561350: INDIA Copper
0561292: MALAYSIA Copper
0561293: VIETNAM Copper
0561354: EMERGING ASIA Copper
0561348: NEW ZEALAND Copper
0561349: INDONESIA Copper
0561347: AUSTRALIA Copper
0561289: SINGAPORE Copper
0561345: PHILIPPINES Copper
Thats all for now. As soon as i get euro packge i'll post more product codes.
Re
Hassan
0560506 POLAND (Copper)
0560545 POLAND (Copper & Dark Grey)
0561116 POLAND (Warm Black & Dark Grey)
0560581 POLAND (Warm Black & Cherry Black)
0560563 POLAND (Warm Black & Burnt Orange)
have a custom firmware .. which disables the FM transmitter .. I'll be changing the product code on mine and changing the firmware ASAP
.. FYI my product code is 0572765 .. has English and Chinese 015 languages
Plesae I need the Euro Product Codes for the unbranded and Unlocked Nokia N85.
thanks in advance
0555817: EURO 1 Copper and Copper
0560498: EURO 2 Copper and Copper
0560506: EURO3 Copper and Copper
0569334: UK, Ireland Copper and Copper
kontraband wrote:I have 0560500: Euro 1 Copper from Finland.
might try that code .. see if they've snuck out a FW update .. cheers 😉
<thinx> Finnish .. hmm likely to get FW updates first .. </thinx>
If I'm not mistaken, NSS doesn't support the N85 yet. Or does it?
Are you guys using Phoenix to flash the product codes?
JohnnyFeet wrote:If I'm not mistaken, NSS doesn't support the N85 yet. Or does it?
with the N85 .. basically if it can see the device it can change that code ..
Hi
My Product code is: 0572765
It is a import from Hong Kong and the FM Tran is Disabled.
Can anyone help me confirm if i can change the product code and flash it with euro code will it work again?
PLEASE HELP.
On the back case it has that transmitter thing, that is the FM or is that the wifi as well????
imation_nz wrote:Hi
PLEASE HELP.
Yeah you can change the code but as yet there is no firmware available to reflash it with ..
So like me you're stuck without the FM transmitter for the time being ..
-seki 😊
seki wrote:Yeah you can change the code but as yet there is no firmware available to reflash it with ..
-seki 😊
but do we even know if that will work once we change the codes???
imation_nz wrote:but do we even know if that will work once we change the codes???
pretty sure .. unless they crippled these .HK models physically .. which I doubt .. we're gonna find out soon enough ..
They didn't .. changing product code to .uk and reflashing happily unlocks the FM transmitter.
seki wrote:pretty sure .. unless they crippled these .HK models physically .. which I doubt .. we're gonna find out soon enough ..
😞 I wanna know now he he
anyone have a link to get NSS web site to download the program to change product codes???
as all the firmware should be the same, if you change your prod code to a euro one nss will tell you your fw is up to date but you can reinstall it, or is that not the case?
I have to say, these keys are much harder than any other phone I have had. Its like playing ps3 hours on end. i have the small corner of my thumb going numb
kontraband wrote:as all the firmware should be the same, if you change your prod code to a euro one nss will tell you your fw is up to date but you can reinstall it, or is that not the case?
So you can't "cross-grade" .. these .HK versions have a custom version of the firmware .. which we're hoping will be toasted ASAP .. giving us the FM transmitter .. In the meantime I'm using my belkin in the car.
well yeah having "flush" keys is a little annoying .. but "playing PS3 .." thats what the bluetooth keyboard is for mate! 😊
I've bought it from phone4u
The product code is : 0572869 black from UK
I'm looking for Arabic code especially from KSA
Could anyone help,pleeeeeeeeeeeeas ? :angel:
imation_nz wrote:anyone know if and when NSS is working for changing N85 product code???
I successful flashed my HK N85 today to the UK (0572869) with NSS V 1.0.38.14.. I then did a reinstall via Nokia Software updater... all looks good... now have FM Transmitter option available.
steve
x2srj wrote:I successful flashed my HK N85 today to the UK (0572869) with NSS V 1.0.38.14.. I then did a reinstall via Nokia Software updater... all looks good... now have FM Transmitter option available.
steve
Thats great!! I confirm this post.. Updating now .. 130.4MB download (didn't try FOTA)
Looking forward to a change 😊
OK weird update .. I got the phone back in a usable state even though the updater is stuck on "15 Minutes to go" ..
I've left it .. but I doubt its actually done anything .. will update later.
