Gigabyte's Bluetooth dongle
8 replies · 2,679 views · Started 14 February 2003
Does anyone know where I can find the latest drivers for The Gigabyte's Bluetooth USB dongle (GN-BTD01). Gigabyte'sc site doesn't have anything.
http://www.gigabyte.com.tw
It came with 1.2.2.9 (or sth like that) and just downloaded MSI's 1.2.2.15
(Widcomm both) and I'll test them later.
Beside, which is the latest...
I don't believe that noone noticed my post?
Anyway, I managed to make the dongle work with PC suite using MSI's drivers.
But I want to get an answer...
Let's put it another way
WHAT WIDCOMM DRIVERS ARE U USING FOR YOUR BLUETOOTH DONGLE?
AEFOX I didn't meant to offend you but 4 out of 6 or 7 threads I have started have 0 replies.
I hope you understand.
Anyway, nice wap site you have.
I can send you some photos to upload them on your wap site, but not for the contest. And you know on which category the photos will be 8) 😃 😃 😃 😮
PM me for more info, if you really want the photos...
hi!..
just joiking and trying to get you on the mood hehe!...
well... 8)
Thanks for your comments about my Wap site... 😉
I am sure that i have many pics for "that" section of my wap site...
but you can send some of yours if youwant to put on it too :roll:
btw! i am using the MSI Bluetooth Software version 1.2.2.15
i am not sure if is it the last version... but was my last update few months and after that i can send files to the PC from the 7650...
where i get it?.. i don't have the url.... but i am sure that you can find it if you search MSI BT on the forum, many people ask for that a few months ago...
well..
cya!
I have the same version.
I found them here.
Thanks anyway...
I'll send you some tommorow, if everything will be ok with my online status.
cya! (or whatever...)
I am using version 1.3.2.7 of the windcom driver, which I found the most complete of all versions.
But don't lose your temper, this has been discussed in numerous threads so far, like that one..
The very reason I make a post about a problem is not always to solve it. Most of the time I solve the problem before even posting it.
Bluetooth was one example, I have already downloaded the drivers and installed them then posted the question (not the problem which was overdiscussed on previus posts) before testing them, and they worked.
I still remember the "new battery treatment" thread I had created.
I knew how to treat my new battery (charging duration), and I also posted some links with info on that.
The only thing I wanted was opinions/experiences, but I didn't get them...
I know that sometimes it is hard to get an anser on some posts (like the thread I created about an AppForge MobileVB version compatible with 7650). But some of them are so easy to answer, and I don't get them answered.
Anyway,it's a long way...
[quote="MemphisX"]...The only thing I wanted was opinions/experiences, but I didn't get them...[/quote]Why didn't you say so in the first place? 😉
With the version included in the package (1.2.2.9 or something), I could not send files to the PC, so I instantly tried 1.2.2.16 with which everything worked, including a tcp/ip connection between 2 PCs with this dongle. Then I installed the latest (1.3.2.7) with some nice little features I hadn't noticed in previous versions, and will keep it till a newer one comes out!
