N96 v12.x Firmware update
53 replies · 30,080 views · Started 07 November 2008
according to Ricky at mobileguru.com there's a new N96 firmware update floating about .. "not for Euro" ?? according to his video blog.
So hopefully you folks who've been moaning about v11 will see good things shortly. 😊
theres a v12 fw executable file iv seen to use with phoenix so it is legit, just gota wait around 2 weeks.
I got a text from "My Nokia" today saying that there is new firmware out for my phone (I'm allready on the V11 software though)
I checked with NSU and I am on the most current firmware. It may have been to tell me O2 have released a new firmware, as thats my original product code
I've downloaded Nokia_firmware_RM-247_EMEA_12.035_v04.00EFAJQROM.exe and installed using Phoenix.
It took a few goes and eventually worked using the "dead" flash mode, with the phone turned off - and switching it on when prompted by Phoenix.
Dare I say it, phone seems a little bit faster even TomTom appears more responsive.
Oh, and all my settings were saved. Phone numbers, access points etc.
Any q's - i'll be happy to try and answer.
buxz777 wrote:flip
how are you finding te v12 firmware please share with us
any screenshots
Just checked with my phone (not locked to anything) and V12 isn't available
No idea where the other poster got theirs, as the link further up is to a hack site and not legitimate
bubs
someone has leaked v12 firmware and it has been uploaded to rapidshare and torrents across the web
if people know how , using flash software you will be able to flash the handset with that v12 that has been leaked
acording to the other user he has flashed his phone via phoneix with v12 -- it isnt avalible via nsu for around 1 week now maybe less maybe more but it should be coming very soon if the file has been leaked
if he has flashed his device i would like to know his comments on the v12 as ive heard it is supposed to be quite a big firmware update for the n96
Do you have to change product code to flash with pheonix?
also can you post some results for this firmware?
speed, battery life improvments?
also does the navi wheel work now?
so far the changes are:
faster UI
no lagging
faster cam opening
63mb free ram on boot
faster bootup time
maps is now wk39
and realplayer is a new version
thats all i know so far
Biggzy wrote:so far the changes are:
faster UI
no lagging
faster cam opening
faster bootup time
maps is now wk39
sweet Thanks
now i just gota update my phone now.
Phone feels considerably quicker to respond to everything. Slicker, don't know how else to describe it.
Real player version is now reporting :
S60 HX cvs_cays221_20080910:05:00:00utc 10 Sep 2008 21:23
Not had a single crash since I applied the update, I don't think i've even rebooted to be honest.
Phone has been used for a 380 mile round trip with TomTom, many phone calls - surfing the .net via Wireless & 3G.
All I can say is ... apply the update with Phoenix, it is worth it. The firmware feels legit - and if it isn't I don't care 'cos it works a treat!
Someone asked for photo's - what do you photo's of? The menu's don't appear any different.
Flip95 wrote:Check your e-mail ...
Hi mate,
if you dont mind could you send me the instructions aswell please, been stuck with this phone for a week now and have not been able to use it....it sooo buggy.
Cheers!
kyd4200 wrote:Hi mate,
Cheers!
:icon14:
Thanks, Tried and failed lol
Problem is I've got Vista X64, tried using vmware to create a xp system and installed everything in order but wont install all the drivers so not takin the chance...........
saj0n1 wrote:Thanks, Tried and failed lol
C'mon ... what sort of nerd are you? 😊
Download a bootable linux CD, make a 20Gb partition on your existing drive, do a dual boot, install XP, install SP3, install phoenix. Rockin.
You'll have a new phone quicker than you can say Antidisestablishmentarianism.
How far are you from Liverpool?
Flip95 wrote:C'mon ... what sort of nerd are you? 😊
Too far.................. that all sounds dead easy lol
faster UI
no lagging
faster cam opening
faster bootup time
maps is now wk39
Dear Friend,
Please give a step by step instructions to update the 12.035 firmware.
Best Regards
APPU
My new shiny N96 arrived yesterday from Vodafone, first thing I did was change the product code using NSS and up grade the firmware to version 12 using Phoenix, it all went very smoothly.
I can't compare what it like before, but the upgrade is not as scary as it seems.
i'm on v11.101 nokia n96 ... :icon13::icon13::icon13::icon13:😡😡
how do i update to v12.035 ?
regards,
Benoit.
You update by using Nokia Software Updater (NSU) from http://www.nokia.com/softwareupdate
If NSU says a new(er) version is not available, then you wait and try again later until it becomes available for your country/region, or operator/network (if you have an operator customized device).
