Anyone else had their 5800 switch off randomly? Mine's done it four or five times recently.
I've got the feeling it's a dodgy battery connection, as if you shake or jolt the phone it'll sometimes do it.
The battery it doesn't seem to be loose at all, and I've tried re-seating it, but it makes no difference.
I'm thinking of taking the phone to an O2 shop to get it looked at this week.
Mine did that and went back to Nokia. Came back wiped and with the new firmware (before it was available via NSU) and has been fine since. :fingerscrossed
i haven't had that one but i had a problem that my phone wouldn't turn on. It would work ok but if you turned it off it wouldn't switch back on for 4 or 5 hours. It's currently back with nokia.
Thanks for the replies.
Tulloch, how long did it take to get fixed, and did you remove the memory card before sending it back?
I'm thinking I might as well delete all the contacts, etc. if it has to go in for repair.
[edit] I've worked out what's going wrong - there's a bit of play in the battery, where it can move ever so slightly left/right. The battery contacts seem a bit dodgy so if the battery moves slightly they break connection and it turns off. I confirmed it by taking the back off and moving the battery with my finger.
I've kludged it temporarily by inserting a slip of paper down the side of the battery to stop it moving.
I'm hoping it can be fixed by a simple battery replacement.
Sounds like a different problem but to answer you anyway: It took 11 days to get it back and I did keep the memory card.
though it's an old topic,but it really made my day ,i had the same problem since few days ago i.e. the phone turns off with the slightest hit,, i tried to stick a piece of paper in the upper side off the battery (proximal to the camera) but the same problem , and after i read this article i put the paper by the side of the battery and the phone no longer switch off, i was about to send it for repair 😊
Thank you, I think if mobile phone shell phosphite good feeling is very good, give a person a kind of poetic feeling not to be stained with fingerprint design, is not easy to dirty dust, easy clean can effectively shock and buffer bump down explosion protection function
