SMS missing functions
7 replies · 2,310 views · Started 30 March 2003
Hi
I miss not getting SMS Status requests or resets that a SMS message has been delivered 😞
Is there any way I can do this?
Thanks 😊
It seems that the phone doesn�t have a report of the send/receiver messsages. It is a negative point that is usually pointed by the critics on the magazines.
Perhaps in a new firmware the problem is resolved... mean while "no reports" for us. I should say that, for me, it is a minor handycap.
at the beginning of your sms put these characters and then a space;
*0#
your operator will be send you the report then
Found the answer
Add ADA in as the first 3 letters in any SMS message and it works on my Network Sonofon in Denmark
I dont really mind nothaving deivery reports. What I think is missing is to be able to created folders to sort out our SMS messages. This is a very simple option, why didnt they include this? We are forced to just keep on deleting our messages because theinbox just gets too full!!
Another is, there is no option to add a cellphone/any number to an EXISTING contact. Everytime you click a number on an SMS message it just gives you an option to add new contact 😞 Well this is an SMS and an Addressbook problem though..
