Flash your P900 Firmware Now!!!
214 replies · 87,968 views · Started 03 December 2003
This is great! I just upgraded from Organiser R1B01 to R2B02, did a format (to remove preinstalled cr@p) and restored my latest backup. Everything went smoothly! 😊
Haven't noticed any differences between the firmware versions though...
I can't be bothered to back everything up and do it yet, but it seems my CDA version is newer anyway?!?
Not sure if Orange will let you upgrade using this service yet because of all the operator specific stuff, but i'll check it out tommmorow.
From the release notes on the SE update site:
Release notes
CDA-number: CDA162003/2
Version: R2B02
Improved sound quality in Office handsfree mode.
Updated Java support MIDP2 - MIDlet signed against Verisign certificate.
Improved capitalization in T9, now capitalizing characters properly.
Enhanced handling of accessories, Bluetooth headset, HBH-200, displays name and phone number of incoming caller.
The Clock screen saver digits has been enlarged for better visualization.
Find function in e-mail application has been improved.
orange' latest is r1c01 at the mo, what happens if you install the latest firmware over the orange one... ?
Don't know, but I think it will loose the orange branding..that's why I don't think it will let you do it.
But I didn't end up going out tonight so i'm going to give it a try now.
just updated mine and it was simple and easy, as long as u follow the online step exactly 😃
i have noticed a huge difference as i had R1A01 (i think 🙄 ). this one seems to be faster loading and better clock too...
would also like to hear what other have to say after they have upgraded theirs.
waks
Orange users are having issues upgrading as Orange has not approved this update yet and they may not..Thus after one attempts to update it will notify you that you already have the latest update.. As I know to-date, there are no Orange users that have been successful at upgrading.. The updater goes through a few checks before it update.. It still gives one the option of upgrading even after the "you have the latest upgrade" notification.. However, going through the painstaking process will still leave one with what they started with... And it will NOT remove that dumb Orange screen tag..
My guess is that they (Orange) might require users to go through them instead.. It makes total sense as I believe users are at risk of voiding their warranty if they fiddle around with the phone through some medium other then Orange. They technically would have to pay to fix your screw up..So if you have a contract phone you might be SOL.... Everything is at your own risk..
For everyone else.. The firmware update is all good... Hence my point on purchasing contract modified phones.. You will run into hassles like this. There are technical and economical reasons why it works out that way. Your carrier will always find a way to keep their arms around the throat of your phone.
User posted imageUser posted imageUser posted imageUser posted imageUser posted imageUser posted imageUser posted imageUser posted imageUser posted image
I couldn't get it to run through my SOCKS5 port so I didn't bother anyway, seems I have an upto date version in any case. 😊
I ran update on my orange p900 every think was ok i had a bluetooth problem that fixd aswell but orange start up mp4 is still there🙄
What does the firmware version actually say???
As I know several Orange members have run the update and the update does notify them that it was successful.. However, after verification the system info still reports the older firmware.. My guess is that you will not find R3C on your Orange phone.. Just a guess..
Old Orange one
Phone: CXC162022 R3B004
Bluetooth: CXC12529 R5D
Organiser: CXC162021 R1C01
CDA: CDA162004/3 R2B01
After Update
Phone:CXC162022 R3B004
Bluetooth:CXC12529 R5D
Organiser:CXC162021 R1C01
CDA:162004/3 R2B01😞 😞 😞
I havent updated mine yet though co im still at home and I have the DeskSpeaker Stand CSS-20 with the USB sync connector DSC-11 which wont work. I have to wait till I get to the office and use the original cradle.
Correct me if im wrond, but would these steps be correct:
1.) Backup using backup and restore
2.) Update online
3.) Format phone to get rid of preinstalled aps (like raven did)
4.) Restore backup?
Question, would no. 3 still be important? Wouldnt restoring your old backup just delete those unecessary aps?
Yes, most likely, but I always do a format before I restore a backup... -Just to be on the safe side I guess... 😃
I only get the following message "
"Please wait...
Checking the installation of Sony Ericsson Update Service"
Please help !!!
Originally posted by Hassan
Old Orange one
After Update
From what you posted your phone obviously hasn't been updated.. The phone firmware hasn't been updated.. I think the problem has to do with your CDA... I think the auto-updater does a check on it and if its not finding what its looking for it will not update the phone firmware.. Contract phones may not be able to go through this process at all...
I just updated my P900 this morning. The whole process took me about 45 minutes. This includes backing up, downloading the update, updating the phone and restoring it up. All in all a pleasant experience. Things I noticed improved are loading times and better texting support like automatically capitalizing the first letter at the end of a sentence. I will post more observations as I go along trying it. Anyway a word of warning. Make sure your phone has enough juice before you do this as it seems to make a considerable drain on your battery. Also make sure you have a very reliable internet connection since I would hate to imagine what would happen if your connection suddenly falters in the middle of the process. Anyway nice job Se! Keep up the good work 😊
Darnit! I dont have SP1 yet on my laptop coz I just reformatted it. So now I have to wait for the windows update to update my windows with SP1 and I know this is going to take forever to do 😞 Is it possible to just download SP1 and update your Laptop Manually?
Hi All,
Collected my P900 yesterday (awesome phone!!!)
These are the firmware details from my sys info (if anyone's interested)
Phone : CXC162022 R3C006
Bluetooth : CXC12529 R5D
Organiser : CXC162021 R2B002
CDA : CDA162004/8 R2A01
Vodafone UK / Contract.
Rgds,
Legin.
Ok, im updating my phone right now.. but this is all I get on the website, should my phone be turned off? Am I missing something here?
Attachments: upgrade service.jpg
Wait like 5 mins, if that doesn't work...wait some more.
Oh you did install the update software didn't you?
Where do you get the update software? I havent installed any update software yet because after the checklist page (make sure your battery is full, make sure you are using the right cradle..etc..) I get this page 😞
Prior to that window I have this, then I just put a check mark and ive waited for more the 20 minutes alread still stuck on that page 😞
Attachments: seupgrade.jpg
Now thats strange. Those were the same steps i went through this morning Muzikfreakah and they worked fine with me. Could it be that alot of people are doing their upgrades now and the network is busy? Try doing it again man
It appears that the Vodafone UK phones already come with the latest version on them.
Guess we'll have to wait a little while to test out the online updates....
