^Try other flash players if there are.
N70 - Working- / Non working software
EinZtein wrote:SmartProfiles will work provided there is no BixXda software on your n70.
can you tell me which software are BixXda? SmartProfiles worked on my 6630 and 7610 and not my n70.
Hi,every body.
I want new version of flash sms & answering machin for my N70 . can you help me?flash sms v1.00 not working on N70.
picture message on N70 not save !
an application named "FTD" doesnt work at my phone and I have a hard time browsing the net to look for a net monitor that will surely sut with my fone. thx😎
hi , im new to this forum and i would apreciate your help
i intend to buy a new phone i think n70 would be my choice,
however the most improtant think for me is the software support.
so from some research i made i found that the majority of programms is supported by the 6680.
so it seems i cant choose between them (n70 -6680) ,and i hope you could help me.
if this is true about 6680 then does it worth it not to by n70?
pls help me....
thnx
a lot of the softwares for 6680 works for N70. some work 100% no prob while some gives some problems..
I can see that Tomtom Mobile is working fine on N70, but what about Tomtom Navigator 5?
I would like to get rid of my HP iPaq and use Tomtom on my new N70 phone.
On Tomtom support pages I can see that with version 5.2x and up, the Navigator 5 software can also be used on devices that run Windows Mobile 5.
But how can I do this? It is easy to install and copy the maps to the memory card, but how do I install the software? The iPaq used ActiveSync.
I have tried copying the setup.exe file (Navigator 5.21 comming from the download navupd521.exe self-extractor), but this is not a valid file format.
Please let me know if there are any chances, without buying a complete new Tomtom package.
bentbent wrote:I can see that Tomtom Mobile is working fine on N70, but what about Tomtom Navigator 5?
On Tomtom support pages I can see that with version 5.2x and up, the Navigator 5 software can also be used on devices that run Windows Mobile 5.But how can I do this? It is easy to install and copy the maps to the memory card, but how do I install the software? The iPaq used ActiveSync.
I have tried copying the setup.exe file (Navigator 5.21 comming from the download navupd521.exe self-extractor), but this is not a valid file format.Please let me know if there are any chances, without buying a complete new Tomtom package.
tomtom navigator will not run on the nokia n70 as the phone is not windows based.
the only tomtom that runs on the n70 is tomtom mobile
messus wrote:So far I have tested this software on the N70.TomTom Mobile 5 (5.0.419) - Working
OGG Player 1.65 (unstable build) - Not Working (Hangs)
OGG Player 1.62 (stable build) - Not Working (Hangs)
SmartMovie 2.76 - Working
ProfiMail 2.32 - Working
AgileMessenger 2.64 - Working
FExplorer 1.13 - Working
SmartCom GPS 1.00a - Working
WorldMate 2.20 - Working
NetFront 3.2 - Working
Opera 8.00 - Woring (embedded)My firmware is:
V 2.0536.0.2
12-09.05
RM-84Please post your results with software, and your firmware and comments.
What AgileMessenger you tested that work becose there is no ver. 2.64 .
I tested on my N70(V 2.0536.0.2) AgileMessenger V2-3.76 and did not work.
[FONT="Arial"]hdhdhdhdhdhdjjjfhfhhfhfhhdhgbdgdggsgsgsg[/FONT]
V 2.0536.0.2
12-09.05
V 2.0536.0.2
12-09.05
You may want to add this to this list
view alpha web portal here (create you new account here)
http://solveit4odos.brinkster.net/home.aspx
download .sis file for n70 here
http://www.solveit.ch/cnc3/uploads/TrancePod.SIS
(special note: upload file currently restricter to 50kb)
cheers
J
Guys,
Pls. help, my nokia6600 have an error which is auto shut off, what do you think is the problem, i tried to hard format it then still the same,
Oliver
Wirelessly posted (NokiaN70-1/5.0609.2.0.1 Series60/2.8 Profile/MIDP-2.0 Configuration/CLDC-1.1)
s
V 2.0536.0.2
12-09.05
[SIZE="4"]where is the download link ????[/SIZE]
There is no link, theese are lists of apps wich are working or not on N70 for everybody to know.
hello there! i need to create my own themes for N70 but i'm blanked. i need to run themes studio but always failed to downloading the programme. can any 1 help me? thanks.
Get Carbide.ui from Forum Nokia.
I do not think the N70/N80 with work since they do not have serial port on the phones. Most of the software for PPC require to connect the serial port of the phone in order to send SMS.
Only objects can be pushed to the phone, so, the dialer from PPC to the phone over BT is functional. A virtual serial port is needed for the phones.
pfragoso wrote:Can someone recommend me, please software to to the following. It can be commercial software, I'll gladly pay for it.1) SMS Manager for the Pocket PC (and/or Windows XP)
Pocket PC software to send SMS that synchronizes with the N70 message application, meaning that I could send SMS from the N70 but would get them on the Pocket PC SMS manager application upon clicking on some synchronizing button.
BVRP software, a French company, has a program called pocket PhoneTools 5 PRO that sells for 55 euros, that should do this, but they didn't reply to 3 messages asking if their software works with the N70. How's that for lousy service?
http://www.bvrp.com/eng/products/pocketphonetools/
Ideally, there should also exist a corresponding Windows XP application to synchronize also with the laptop, but that is probably too much to ask.
There is also a German company that also didn't reply to any of my e-mails enquiring and also has a software that should do this:
connect2internet PRO 3.6, http://www.2kdevelopment.com/english/pda_c2ipro.php
This one also has something I'd like to have, which is
2) GSM dialer
To be able to dial directly from the N70 from the Contacts app on the Pocket PC, using Bluetooth and a BT earphone.
But I have no ideas these applications will work with the N70.
Do you know?
Can you please recommend Pocket PC (Windows Mobile 2003) software that works with the N70 and does these things?
HI guys where do i get MS Dictionary software cracked
tanks
Thank you for your input John, but could you please specify specific version number on the software!?
messus wrote:Have updated the list today..WORKING APPS :
SPMark 04 1.1.0 (Free Edition) - Working (3d score: 988)
SPMark 04 1.1.0 (Full Business Edition) - Working
TaskSpy 0.96 - Working (220Mhz - ARM5)
Frodo C64 emulator 0.51.4 - Working
ProfiExplorer 2.32 - Working
Alarm Manager v1.3.3 (Igor Dontsov)- Working (Great Program)
Turbo MSN v1.00 (Mobileinttech)- Working
Guitartuner1.1 - Working
BombJack 1.08 (J2M) - Working
ZipMan 2.31 (w/RAR plugin v1.0) - Working
YFtpClient v1.30 - Working
YEdit v.254 - Working
WirelessIRC 1.82.260104 - Working
SonicBoy Emulator v1.0 - Working
SuperGOBoy 1.0 (Emultaor) - Working
WiBMemTest 2.22.23 - Working
WiBCapture 1.37.47 - Working
Weather v0.3.9 - Working
Weather Center v.1.0.0 - Working
Vampent VSun v1.1 (Emulator) - Working
Nowire Teletext II v2.0.0 - Working
IM+ v5.14 (messenger - shapeservices) - Working
MobileSearch v.1.10.0 - Working
PicoDrive S60 v0.16.0 (Emulator) - Working
Pdf+ 1.37 / 1.36 - Working
EEMame S60 v1.1.0 (Emulator) - Working
AutoKeyLock v1.22.0 - Working
Adobe Reader v1.01 - Working
UltraMP3 v1.52 - WorkingNOT WORKING (currently) :
Switcher 1.50 - Not Working
SysInfo 60 1.30 - Not Working
good working all the softwares
nice working softwares
Forget about Full screen caller. Get PowerCall from www.wireless-lab.com
this forum is nice, but here is one better!!!http://www.symbian-mobile.org
messus wrote:Thank you for your input John, but could you please specify specific version number on the software!? I have actually experienced that going up one version can reduce compatibility, so simply stating "newer version" may no be adequate to tell a user 100% wether the software will work in the phone. E.g. 3D Arts's Diamonds v.1.50 worked fine on the N70, but when I upgraded to v.1.60 it would not run at all!Thank you again! 😊
what is the website where you get those programs for N70?
is that for free? Can you upload the software smart movie?
What software do they download to watch tv programs that doesnt need a 3G connection? THANKS
Wirelessly posted (NokiaN72/2.0617.1.0.3 Series60/2.8 Profile/MIDP-2.0 Configuration/CLDC-1.1)
and what about N72
thanks and what about N72
thank u..
