On my Factory un-locked Nokia n70 fw2.0536.0.2
Working:
AlarmManager 1.3.3
CodeGaurd 1.03
ContactManager 1.06 (great app for transferring ALL detail of contacts between s60 phones)
EarthExplorer 1.0
MoneyTracker 2.0
RescoNews 1.12
RescoViewer 4.30.2
UltraMp3 1.52
SoundMonitor 1.0.1
ColorPicker 1.0
MobileRadio 1.02
NetFront 3.2
Symella 1.0
TrafficEdge 1.2.1
ZipMan 2.31 (supports embedded objects too!)
Was working, now isn't(might have something to do with LM):
SmartProfiles 1.06
EzSMS 1.0
Never worked:
Oggplay 1.65
WMAPlus 1.0
hey, i just installed WMAplus! on vodafone N70.. i cant get it to work. But able to play wma song fully.
any problem with this program?
Messus,
I have a Holux GPSlim 236 with Serial Number 528-xxx dont know which firmware or how to find out?
My N70 has V2.0537.1.7 18-09-05 RM84
I have the same problems posted by most users in that the connection stops or hangs with Tomtom mobile 5.2.
Can you advise what I may be doing wrong.
Thanks in advance and sorry if this is in the wrong place.
Al Pal
I tired installing the Arabic/Farsi on Symbian by PSILOC on the N70. the installation failed to complete and now the phone is all messed up. I am unable to write SMS and cannot edit any contact or add groups.
can some help please
my firm ware version is
V 2.0536.0.2
12-09-05
Hi guys,
is anyone using Mobimate Worldmate on the N70.
I'm having some problems (all be it minor) with the way it operates.
First
Automatic Update does not happen even though it is set to update daily.
Second
"About Worldmate" - when I try to access this option, nothing happens.
Third
When I close Worldmate, it exits to the Menu screen and not the standby screen.
Anyone else got the same problems?
Anyone knows whether there are any application similar to Smart Profile and EProfile? Free one would be even better.
EProfile states that it's compatible with N90 but it's really expensive. Smart Profile is reported here that it's not compatible.
Anyone?
[SIZE="3"]hello
i need agile messenger 2.64 for n70 please help me
Regards Abtin[/SIZE]
messus wrote:So far I have tested this software on the N70.TomTom Mobile 5 (5.0.419) - Working
OGG Player 1.65 (unstable build) - Not Working (Hangs)
OGG Player 1.62 (stable build) - Not Working (Hangs)
SmartMovie 2.76 - Working
ProfiMail 2.32 - Working
AgileMessenger 2.64 - Working
FExplorer 1.13 - Working
SmartCom GPS 1.00a - Working
WorldMate 2.20 - Working
NetFront 3.2 - Working
Opera 8.00 - Woring (embedded)
My firmware is:
V 2.0536.0.2
12-09.05
RM-84
Please post your results with software, and your firmware and comments.
[SIZE="3"]hello
gadget_sa wrote:Hi guys,
I was using Worldmate on my Sendo X before. Nice App.
But the new Worldmate Version 2005 is too expensive and only for one year.
Additionly, the software already hangs up when starting on my new N70 (FW2.0536.0.2). So I was not longer interested in this software.
Sian wrote:Anyone knows whether there are any application similar to Smart Profile and EProfile? Free one would be even better.EProfile states that it's compatible with N90 but it's really expensive. Smart Profile is reported here that it's not compatible.
Anyone?
SmartProfiles will work provided there is no BixXda software on your n70.
hi EinZtein
thanks for the tips. have purchased sProfile from Symbianware. love the convenient of not switching the profile manually day in day out. 😊
my firmware is -
V 2.0536.0.2
12-09.05
RM-84
Working applications:
- sProfile 1.06 (the backgrd image in Adv Profile setting doesn't seem to work too well.. cause lag to phone)
- zi Predictive Text Suite.
- autolock
- Switcher 1.6
- power call (not too well.. can have big caller id, but can't access 'option' to activate loudspkr)
- fscaller (not too well.. don't add it to 'Go To'.. will paralyse 'Go To'😉
- MGS MVRPool v1.1, Mad Macs v1.0 and Noumena Mahjong
- BibleReader 60_2 (from www.olivetrees.com)
There's a new version for PowerCall. Now it works pretty well.
my firmware is -
V 2.0536.0.2
12-09.05
RM-84
- Autolock
- Switcher 1.6
- Power call (don't need FSCaller anymore!)
- Forward
- Lookup
- Torch
- XXL Screensaver 1.09
- FExplore 1.15
- TaskSpy 0.92
- CellTrack 1.11
Update!
Tried Sysman v1.01 from SymbianWare. Works well.. tried Appman v1.04 but it didn't show 'add application to Go To/Favorite' under option. so, may not be compatible with N70.
My firmware is -
V 2.0536.0.2
12-09.05
RM-84
- Autolock
- Switcher 1.6
- Forward
- Lookup
- Torch
- FExplore 1.15
- TaskSpy 0.92
- CellTrack 1.17
- Smsreminder 1.00 (don't autostart after off on the phone. =( sad..)
- Appman (don't have option to add to Go To)
- Sysman
thanxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Anybody Can Give Me A Sound Recorder For The N70?
Psiloc Extended Profiles 2.33 works
2.32 was a little buggy on the schedule profile
i tried to install the psiloc to my n70 but it says unable to install after half way. any idea?
not too sure about that, but did you download the latest version of the psiloc website? on top of that, im not too sure about previous firmware, im currently on 3.0546.2.3
I just tried 'Reminder' from Unteh on my N70 and it set my N70 on reset twice.. thank God I managed to stop it.
Anyone else tried this and has the same problem?? Or other problems... comments?
i just tried to download the psiloc erecorder again but ...kaput... cannot. It said unable to install when it was half way installing on the phone. What can i do? do anyone have any other software for a recorder in the n70? i want one that can last longer than 1 minutes
How about updating the first post with a list of working apps? That way new users dont need to read through the pages.
sorry!! For going out of the track��.actually m planning to buy Nokia N80 so was doing some research work, one of my friend recommended of visiting this forum to check out sme real good reviews about it but m unable to find ne postings for it�.plz help!!!
I did sme research work and found it to be a beautiful rich 3G multimedia device �.it reminds of Nokia 7650 as all the reviews say!! It weighs only 134 grams�and provides fast internet access with sensitive browsing��it also incorporates large internal memory of up to 40 MB ��.I found it pretty interesting. Also got some reviews check out !!! If some one is interested of course 🙄
http://www.inods.com
http://www.mobile-review.com
:con?
hi guys i am new to this forum and i could do with some help. i have just got the nokia n70 my problem is adobe reader i have tried to install it on to my phone. it goes through the install proccess no problem but after the instal is complete it is no where to be found. i have installed other applications ie; fs caller, tomtom, profiexplorer and an alarm manager. all these appear in my menu under the myown icon but no sign of the adboe programme. i tried installing it both the phone and memory card. it works fine on my 6600.
any help would be appriciated the version of adobe reader is 1.04
cheers
it could be under your 'Office' folder
cheers guys
no its not in either any other ideas. i have tried installing it again it goes through the proccess no problem but i just cant find it
Vnes v2 is running buggy even with the correct colour version.
Vnes v1.51 runs with speed problem. General > FPS > Normal - The game runs too fast!! Set the FPS to 40-60 and it should run just perfect.
Can someone recommend me, please software to to the following. It can be commercial software, I'll gladly pay for it.
1) SMS Manager for the Pocket PC (and/or Windows XP)
Pocket PC software to send SMS that synchronizes with the N70 message application, meaning that I could send SMS from the N70 but would get them on the Pocket PC SMS manager application upon clicking on some synchronizing button.
BVRP software, a French company, has a program called pocket PhoneTools 5 PRO that sells for 55 euros, that should do this, but they didn't reply to 3 messages asking if their software works with the N70. How's that for lousy service?
http://www.bvrp.com/eng/products/pocketphonetools/
Ideally, there should also exist a corresponding Windows XP application to synchronize also with the laptop, but that is probably too much to ask.
There is also a German company that also didn't reply to any of my e-mails enquiring and also has a software that should do this:
connect2internet PRO 3.6, http://www.2kdevelopment.com/english/pda_c2ipro.php
This one also has something I'd like to have, which is
2) GSM dialer
To be able to dial directly from the N70 from the Contacts app on the Pocket PC, using Bluetooth and a BT earphone.
But I have no ideas these applications will work with the N70.
Do you know?
Can you please recommend Pocket PC (Windows Mobile 2003) software that works with the N70 and does these things?
I installed the SWF flash player from
http://my-symbian.com/s60/software/applications.php?fldAuto=1633&faq=4
and it most definately isn't working.
In fact, whenever I now press the menu key, I get the text 'Menu' at the top of the screen, but it then simply reverts to the previous screen.
Any help you can give me would be appreciated,
Alex
