Route66 and N80?
65 replies · 18,614 views · Started 13 July 2006
Hi all,
Having got bored and frustrated waiting for TomTom to release an N80 version of their Mobile 5 product, I bought (direct from www.66.com) the latest British version of Route 66 Version 7, which they state is fully compatible with the N80.
Guess what.... random GPS dropouts, map freezing and program terminating repeatedly when planning certain specific routes (postcode to postcode).
Has anyone else any experience of Route66 on the N80 and are there any hints and tips to make it run reliably?
P.S. I have the latest (?) FW V3.0618.0.2 23-05-2006 RM92 Nokia N80 (55.01)
Dez:frown:
Sorry to hear that! This is what i got from ROUTE 66 Customer Support
on Jun 28
Dear Sir,
We have to inform you that Mobile 7 S60 North America is not compatible with Nokia N80.
Kind regards,
Mirela MARUNTIS
I don't have Route 66, but I did get Wayfinder.
I'm suffering all sorts of GPS dropouts too, but I don't think it's Wayfinder at fault, it's the horribly poor bluetooth on the N80.
nostarwhere99 wrote:Sorry to hear that! This is what i got from ROUTE 66 Customer Support on Jun 28
Dear Sir,
Kind regards,
Mirela MARUNTIS
Thanks for the info.
The R66 website specifically says the N80 is compatible with the latest version, and my Invoice even states N80 as part of the order.
I will wait for R66 Customer Support reply, and if they have no suggestions, will ask for my money back - either as a refund or by contacting my credit card.
Shame, as there's currently no other N80 compatible GPS applications...
Dez
dez_borders wrote:Thanks for the info.
Dez
2 responses from www.r66.com today:-
1.
Dear Customer,
More and more indecations are that the problems, concerning bluetooth and memory of the N80 are caused by the firmware of the N80. We advise to wait untill Nokla releases a firmware update for the N80.
With kind regards,
Rob, VEEN
2.
Dear Customer,
This has nothing to do with Mobile 7. Our product Mobile 7 is compatible with Symbian series 60 interface 3.0 !!! like the N80. The N80 however has problems with buetooth and memory due to the firmware of the phone. Even compatitor navigation software will have the simular problems when they will release a version. unless nokia updates the firmware of the N80.
With kind regards,
Rob, VEEN
The first email was in response to my fault report.
The 2nd email was in response to me asking for my money back because Route66 doesn't work properly on the Nokia N80.
For information:-
I specifically ordered an N80 version of Route66 from the r66 website. My invoice/delivery note states 'N80' so that's what I ordered, not a generic S60-3rd version!
Tomorrow I will contact my credit card company and dispute the transaction to try and get my money back.
I STRONGLY advise N80 owners in this forum to avoid buying Route66 from www.r66.com at the present time!
Cheers,
Dez
woow thanks for the advice, i was going to order it, instead the gps unit, but, i want to try just buying a gps unit since N80 has its own GPS app
I am using the 5 day trial of Wayfinder currently on my N80 with a bluetooth GPS adapter and a Parrot car kit.
The bluetooth connection dropped out 3 times this morning to the GPS however the connection to the car kit stayed alive.
This behaviour was seen in the early versions of the N70 firmware as well.
_Dx_ wrote:woow thanks for the advice, i was going to order it, instead the gps unit, but, i want to try just buying a gps unit since N80 has its own GPS app
No problem - glad my info saved you some money and stress!
Finally yesterday I received an email from Route66 Support Team with a Returns address so I am getting a full refund (hopefully including postage)
Cheers,
Dez😎
I couldn�t wait any longer for a new version of TomTom so thought I would buy a Route66 Mobile 7. I thought it would be useful for my holiday journey from Manchester to Great Yarmouth. The postcode holiday for the caravan site is NR30 4HG and when it attempted to calculate the route it kept crashing. I�ve re-tried several times but no luck, so I then tried Great Yarmouth as a town and that worked (but this is not the point as I need a pin point location). I also experienced losing a GPS signal more than several times during my journey. When it did loose the signal it sometimes freezes on the directions screen without any notice. My home postcode of M26 1AG also crashes Route66. I was in Great Yarmouth and attempted to find the tourist information office using the Route66 and that was hopeless. It would find the address/location but when it attempted to calculate the direction it would crash.
The GPS receiver was a TomTom and when Route 66 did say it lost a signal, the TomTom GPS reciver would still be flashing to state a signal is still active.
I am definitely getting in touch with Route66 support for a full refund unless they provide a patch/fix.
VJ_UK wrote:I couldn’t wait any longer for a new version of TomTom so thought I would buy a Route66 Mobile 7. I thought it would be useful for my holiday journey from Manchester to Great Yarmouth. The postcode holiday for the caravan site is NR30 4HG and when it attempted to calculate the route it kept crashing.
The latest version of Route66 is supplied with a Britain map of over 200 Mb. I also experienced the application crash when entering an ML1 postcode. When I replaced the map file with an older version (143Mb) route calculations stabilised.
Unfortunately, the GPS Bluetooth connection still dropped out every 5-10 minutes, making the product essentially useless.
Basically, TomTom and others have not released an N80 version of their products yet so why did www.R66.com do so WITHOUT proper testing?
If you paid via Credit Card, contact their Retail Disputes department if R66 doesn't offer you a full refund...
Cheers,
Dez
This is my response from Route66 in which I said that the software is unstable as it kept crashing when calculating my home address details, my holiday destination and disconnected more than several time during journeys. They should have a product recall as the software has too many issues. I'd also requested for a refund but no mentions of that, I'll have one last attempt, if that fails I'll get in touch with credit card company.
Dear Customer,
We supported the N80 recently, however The N80 has problems with Bluetooth due to the firmware of the phone. We have confirmation from Nokia that this problem is caused by BT power consumption reduction change which was introduced in the latest firmware. Nokia is working on a fix that will be published shortly
Of course we are doing our outmost to fix eventual "bugs" yourself, however we kindly request you to fill out attached error report form and return the form to us.
We thank you for you cooperation.
With kind regards,
Rob, VEEN
VJ_UK wrote:this problem is caused by BT power consumption reduction change which was introduced in the latest firmware
Can anyone who's having this issue confirm the firmware version that this refers to please? I'm running v3.0614.03 11/04/2006 RM92 and am awaiting delivery of a Holux GPSlim 236 unit - am I likely to have the same issue?
SW Version V3.0617.0.6 03-05-2006 RM-92 is concerned. I don't know if the previous version is concerned also.
gb229 wrote:SW Version V3.0617.0.6 03-05-2006 RM-92 is concerned. I don't know if the previous version is concerned also.
K thanks for the quick reply. I'll post here once I get and test the unit (it's in the air from Hong Kong at the moment for half the UK price 😊 )
My problem exists on the current version which is same as above..
I personally don�t think it�s entirely a bluetooth/firmware issue. I think there a problem in general with Route66 software. 😡
VJ_UK wrote:I think there a problem in general with Route66 software. 😡
There are some fairly uncomplementary posts about the software on the relevant pocketgpsworld forum.
Think I'll explore other avenues for the moment and wait for the S60v3 navigation software to mature a little. Only really bought the Holux to play with as I already have an old (and slightly 'modified'😉 TomTom Go for the car.
dez_borders wrote:Finally yesterday I received an email from Route66 Support Team with a Returns address so I am getting a full refund (hopefully including postage)
I've attached the latest comment on my battle with Route66.
I've had to use the product key so dont think I will be eligible for a refund via Route 66.
Dez - Did you get a similar response?
Dear Customer,
Only ROUTE 66 products of which the productkey NOT have been used, will be refunded. If that is the case:
Please ship your original ROUTE 66 product, with the original Invoice and a copy of this e-mail enclosed by REGISTERED mail to the following address:
ROUTE 66 Geographic Information Systems B.V.
Att.: Logistics Department
Brouwerstraat 36
NL-2984 AR Ridderkerk
The Netherlands
As soon as we have received the above mentioned items we will refund the amount you paid.
With kind regards,
Rob, VEEN
got the britain and ireland route 66 and as a tracking application it is great, tracks well and I like the speed warning should I exceed the trigger I set.
But when I try to calculate or if I do manage to calc a route and route66 has to recalc the application will shut down.
Very frustrating.
I will try installing the previous version of the Britain file and see what that does.
I do not get bluetooth dropout atall. I have a noname cheap and nasty gps bluetooth receiver from ebay (�28 delivered)
Other than not being able to plan a route I am actually impressed with this (I had tomtom5 previously and thought that was poor)
VJ_UK wrote:I've attached the latest comment on my battle with Route66.
Dear Customer,
Hi m8,
Mr Ron, VEET, has a lot to learn about customer care... and European Union distance selling / Consumer Protection laws!
If your invoice/despatch note is like mine, it clearly states you bought the product for use on a N80, and as it doesn't work on the N80, R66.com are clearly selling goods 'not fit for purpose' and you are entitled to a full refund.
Clearly Route 66 is NOT capable of running on the N80. (I can forward anyone that need a copy of an email I received where R66 admit the fact it doesn't work on the N80.)
Obviously the only way you can find out the product doesn't work on the N80 is to install it, so use of the key is irrelevant - the software is faulty / useless!
If you paid with a credit card then phone the CC company's Retail Disputes department and ... er... Raise a Dispute. Your credit card company will authorise you to send the product back ('Royal Mail International Signed For' cost me about £6.50). Once R66.com ACCEPT OR REJECT delivery (it doesn't matter which), contact your Credit Card company again and they will FORCE R66 to refund your cash.
Mr Ron needs to be re-trained (or 'redeployed' out of customer support).
P.S. Demand a refund of the Return postage fee, as Route 66 are at fault and you are entitled to claim all reasonable expenses back.
Cheers,
Dez :icon1:
well, strangly it does indeed work fine with the old version of the Britain file. So its nothing to do with the n80. No bluetooth dropout atoll.
Route66 ain't doin to good....
Cheers for the advice again Dez. :icon14:
I�d sent a reply to Mr Ron VEET explaining that I had to use the product key to check that the software worked on the phone. I also explained that the Route66 is absolutely hopeless as it cant even calculate my home address properly without crashing. I explained that they have withdrawn its compatibility on there website which proves that this doesn�t work on the N80. And guess what, they�ve not replied now! 😡
I phoned up my credit card company (Barclaycard) yesterday and advised them of my situation and they said as I�ve installed the product using the product key, the software is classed as used goods. Therefore they are unable to help. :frown:
Think I maybe a little screwed with a Route66 that doesn�t work. :con?
Scotchgitt � How do I get hold of the old version of the Britain file?
VJ_UK pm me you remail address and I will see what I can do!!
I have currently got both britain files on the phone (renamed the old one britain2) so I can switch between them to try to get it going.
Mr Rob VEEN sent me a reply yesterday saying I had to free up phone memory, I currently have 7mb free so will try to free up more and see what happens.
VJ_UK: how much free phone memory do you have?
Right now I�m fuming now cos someone is telling me porkpies and I think its Route66. 😡
I emailed Nokia to find out how I can find the latest N80 firmware and my experience with Route66 and the possible bluetooth problem with the phone. This was there response �
Dear Sir/madam
Thank you for contacting Nokia Helpline.
With regard to your email concerning the Nokia N80, we would like to advise that to find out the new releases of firmware please contact your nearest Nokia Authorised Service Point.
Your nearest Nokia Authorised Service Point is as follows:
Name: Carphone Warehouse
Tel: 08707204180
Secondly with regards to the email you have forwarded from the third party, Nokia are not aware of any issues with BT power consumption. Nokia would like advised that you contact the third party that supplied this information to discuss the issue further.
Please don't hesitate to contact us again if you have any further questions.
With best regards
UK & Ireland Team
Nokia Helpline
Scotchgitt � I have 32MB Free memory on the phone and 1661MB Free memory on the memory card.
Mr Veen said you need 6mb free memory for the aplication to run, I currently have 12mb free and it still crashes but the old map works ok still.
Well my Holux GPSlim 236 unit arrived yesterday and I've been playing with the trial version of Wayfinder Navigator and Nav4All over the weekend.
Over 4 separate tests each of 30 minutes or more I've had no GPS dropouts running firmware v3.0614.03 11/04/2006 RM92.
VJ_UK wrote:...I explained that they have withdrawn its compatibility on there website which proves that this doesn’t work on the N80. And guess what, they’ve not replied now! 😡
I phoned up my credit card company (Barclaycard) yesterday and advised them of my situation and they said as I’ve installed the product using the product key, the software is classed as used goods. Therefore they are unable to help. :frown:
Think I maybe a little screwed with a Route66 that doesn’t work. :con?
Scotchgitt – How do I get hold of the old version of the Britain file?
Route 66 Support are no longer replying to my emails, but since we are all quoting Mr Ron Veet in these forums, I guess it's hardly surprising. :tongue:
I suggest you contact Barclaycard again and advise them that THE SOFTWARE IS FAULTY AND DOES NOT WORK - tell them that unless they contact the supplier to get your money back you are going to take the matter up with the FSA (Financial Services Authority) and raise an official complaint with the Financial Ombudsman. You have clearly been supplied with faulty goods, and they MUST deal with your complaint. Don't take NO for an answer, keep asking for a supervisor or manager and if they still refuse, then ask them to record your complaint on your file and to supply contact details for the FSA and the Ombudsman.
As for the question of earlier versions of the GB map, have a look in Bit Torrent or EMule. But ONLY do this if you have a legal copy of Route 66.
Dez
I bought a Bluetooth GPS receiver from mobilefun.co.uk for �40 and have been playing with it on my N80 using SmartCom GPS. I haven't done any large amount of driving, but had it going on a 7 minute trip with no drop outs.
Smartcom isn't the best progra,m though and the map I ahve got isn't calibrated properly or detailed enough, so I was thinking of trying Nav4all. Being on Orange Pay as you go though, map downloading could get expensive, so how does it work exactly. ARe the maps stored onyour phone for future use once downloaded?
Nav4all developers appear to be spamming forums as well. A search for Va4all forum brings loads of results from people with similar names using similar terminology (i-net for example). I don't know i fi can trust a company like that.
