The new version of the N80 IE !!, DOWNLAOD LINK....
i am from argentina, and i am waiting the EMEA version... Check this... in other forums are flashing the n80! its work fine!
4.0632.0.38
13-10-2006
RM-92
N80IE
DOWNLOAD: http://rapidshare.com/files/5106380/N80_RM-92_IE_APAC_PR_v15.00_SW4.0632.0.38.rar
I CONFIRM THE DOWNLOAD
I CORRECT THE DONWLOAD... PLEASE INFORM OF THE UPGRADES...
This says that the VOIP is able!
Gizmo is able now in ours N80.... i am waiting the EMEA pack with spanish version.. but this have the english.
juato4 wrote:I CORRECT THE DONWLOAD... PLEASE INFORM OF THE UPGRADES... This says that the VOIP is able!
Try TIVI .. its a good sip VOIP that works with N80 standard
Do you have the link for the download for the N80 please ..
gizmo looks quite good and I would like to give it a go ..
anyone given this a go?
wouldn't mind flashing mine with the internet edition firmware, any real advantages, other than wlan wizard and voip?
already got the wlan wizard on the internet edition from nokia and works fine on my normal n80
wolverine1982 wrote:anyone given this a go? wouldn't mind flashing mine with the internet edition firmware, any real advantages, other than wlan wizard and voip?
you dont need the internet edition for VOIP to work ..
the download link is this:
this work in standard N80.. try and engoy.. i am waiting the EMEA version but i have friends of others forums that was try this version and work great!
Bye.
Just updated my firmware with 0540839 APAC 1 Smooth stainless internet editon,
Phones working without any problems.
You did get a different font and a dictionary
Stu
v4.0632.0.38
13-10-2006
rm-92
nokia n80 11
Remember to back up your stuff
Also installed the Internet Edition Firmware. Only languages in my variant are English, and what looks like Chinese. The fonts are slightly bigger than my older firmware.
One problem I have spotted is that it won't play .awb audio files any more 😡
Well... please configure gizmo and tell us how its works!!... congranulation.. you have a N80IE now! your phone cost much more!, jaja!
Bye
hello ...i updated my N80 to N80 RM-92 IE APAC PR v15.00 SW4.0632.0.38 ....i got the message that ..the update...was ...successfull ..and after that i tryed to turn on the phone...i get the nokia logo...and..then i get a bip..and my phone is not starting anymore...can you please tell me what can i do?..to fix that😞(....thx in return!😡
do you haved charged your battery??
yes the battery was full ....
I'd tread with care on this one as I've just killed my N80
Using the Diego/Phoenix software and the latest v4 firmware tried to upgrade my N80 on Vodafone.
All was going fine until the end of the firmware upgrade when the phone should be restarted to complete the update. I won't restart. Powers up, but doesn't do anymore than the screen lighting up (white) and the blue flashing light.
blkcliostu wrote:Just updated my firmware with 0540839 APAC 1 Smooth stainless internet editon,Phones working without any problems.
Stu
v4.0632.0.38
13-10-2006
rm-92
nokia n80 11
is it possible to update the n80 with the nss and nsu meathod using the code above, i dont wana use the pheonix meathod.
juato4 wrote:The new version of the N80 IE !!, DOWNLAOD LINK.... i am from argentina, and i am waiting the EMEA version... Check this... in other forums are flashing the n80! its work fine!
Many thanks for the link and I can confirm it flashed fine with Phoenix on my Euro Black N80.
I flashed using code 0539859 (APAC 1 Pearl Black Internet Edition)
Interestingly though, *#0000# does NOT report the IE prefix...
V 4.0632.0.38
13-10-2006
RM-92
Nokia N80 (11)
Any ideas why it doesn't report (11IE) installed into my phone?
Anyone know of a download link for the EURO language packs?
Dez
it doesnt says IE.
The EMEA version is for download in www.clubnseries.com
regards.
juato4 wrote:it doesnt says IE.The EMEA version is for download in www.clubnseries.com
regards.
Cheers m8, downloading it now.
I actually found some font issues with the Asia version. Some extended/symbol characters are displaying as squares e.g. []
Would prefer Language 01.
Thanks again!
Hi, Juato,
Can you give methe direct link for the EMEA ? I don't understand spanish !
Cheers !
wolverine1982 wrote:is it possible to update the n80 with the nss and nsu meathod using the code above, i dont wana use the pheonix meathod.
Ive used phoenix on two phones and havent had a problem yet.
i like the wlan scanner thats handy
regards.
Thanks, I am now on the following:-
V 4.0632.0.38
13-10-2006
RM-92
Nokia N80 (536.01)
One thing I have noticed (via Taskman)... after powering up the N80, I used to have about 17Mb RAM free. Now I only have about 15Mb. Presumably the new IE functions take up more phone RAM? This could have a downside on the Web browser with large web pages (e.g. eBay). I will do some testing and let folks know if there's any differences to browser reliability.
Dez
Can I just download gizmo as a stand alone program, and install it, or do i need a firmware upgrade to IE in order to use this software....been on the gizmo web site and cant seem to download it from anyware, not even my phone...any idea`s people?
jedi134 wrote:Can I just download gizmo as a stand alone program, and install it, or do i need a firmware upgrade to IE in order to use this software....been on the gizmo web site and cant seem to download it from anyware, not even my phone...any idea`s people?
to use Gizmo you have to have the N80i or upgrade your N80 to the N80i Firmware....Gizmo wont install otherwise..
have you guys if its available tried installing the gizmo.sis file that it downloads? if thats what it does?.. What im trying to say is you guys with gizmo on your phones do you have the install prog .sis file I presume. will it work that way? or do I still need ie on the phone.
jedi134 wrote:have you guys if its available tried installing the gizmo.sis file that it downloads? if thats what it does?.. What im trying to say is you guys with gizmo on your phones do you have the install prog .sis file I presume. will it work that way? or do I still need ie on the phone.
It says somewhere on the website that Gizmo app will not work with the standard N80..I also tried to install and the installation failed, aparantly the app is an easy way to configure Gizmo with the extra sip stufff of the N80 Internet Edition......
read this
http://forum.gizmoproject.com/viewtopic.php?t=4471&highlight=n80&sid=eede4a1250b5e907982485bca9425246
Cool ....where do people get the gismo .sis file from....I cant find it anywhere....am I going blind? cash can you help me out here?
have a look here
https://gizmovoip.com/learn/nokia_gizmo/
There is a link for download
Thanks CASH but what is the difference between the gizmo plug in (which I can download) and the gizmo download, the later wants me to do it from my phone, but when i access the page there is no option to download the software ( is this due to me not having ie firmware installed) I read the other forum and cant see why gizmo wont work on a standared N80 as using TiVi Voip works....is this a fault with the sis file like the other forum says or is it, nokia protecting it for use on only certain phones?
