[HOT][NEW] N80 RM-92 IE APAC PR v15.00 SW4.0632.0.38
176 replies · 193,025 views · Started 29 November 2006
Hey Cash
ok stupid question I know but I'm missing something here. How do I register my user name and password to Gizmo ? Do I do it from my phone or from my pc ?
Cheers
micscave wrote:Hey Cash
Cheers
well you can sign up from your PC...you can download the Gizmo client for PC and when you run it you get the option to register an account,
then you enter those account details into your phone in the options where you try to connect Gizmo to the network
But there does seem to be a problem with phones not connecting to the Gizmo network, specofically E61, but I also have problems connecting so this may also be an N80i problem also..
http://forum.gizmoproject.com/viewtopic.php?t=3834
I have downloaded Phoenix and cracks and tried installing all afternoon, on two different computers. No joy. When i managed to finish installing, after i restarted and clicked phoenix, it kept asking for dongle, replaced cracked files and then it said 'illegal operation'. Tried on a laptop, could not go past the 'dongle required' in installation phase, no matter how fast i clicked to overwrite the dll files. Then i tried on a win2000 (second os on my pc) and could not make it work there either. I am at the end of my patience, anyone had these problems? I can see all of you guys managed to do it without problems, i thought it was my computer first, but the second computer didn't work either.
dunarea wrote:I have downloaded Phoenix and cracks and tried installing all afternoon, on two different computers. No joy. When i managed to finish installing, after i restarted and clicked phoenix, it kept asking for dongle, replaced cracked files and then it said 'illegal operation'. Tried on a laptop, could not go past the 'dongle required' in installation phase, no matter how fast i clicked to overwrite the dll files. Then i tried on a win2000 (second os on my pc) and could not make it work there either. I am at the end of my patience, anyone had these problems?
you have to be really really quick to open the crack and also quick when it asks you to overwrite all files...it took me 4 attempts to get the timing right 😊..
I had similar probs, after uninstalling and reinstalling about 20 times if finally seems to work, but is very flakey...throws up errors when ever it feels like it, crashes intermittently.....No way do I want to flash my phone when its like that......before I condemn it I will try it on a fresh install of XP if it fails then I give up.....People on here seem to have no probs thou, maybe they would like to share their success with us feeble ones😉
jedi134 wrote:I had similar probs, after uninstalling and reinstalling about 20 times if finally seems to work, but is very flakey...throws up errors when ever it feels like it, crashes intermittently.....No way do I want to flash my phone when its like that......before I condemn it I will try it on a fresh install of XP if it fails then I give up.....People on here seem to have no probs thou, maybe they would like to share their success with us feeble ones😉
Have you removed every other instance of nokia related software first before you install pheonix, the NSU, pc suite, drivers etc...
yup totally clean, i cant get it any cleaner unless i install a fresh xp install.....I have tried everyting but like i say its very unstable....so i think my best be is a fresh install.... I cant stop saying install.......thats now many times ive installed this software🙄
jedi134 wrote:yup totally clean, i cant get it any cleaner unless i install a fresh xp install.....I have tried everyting but like i say its very unstable....so i think my best be is a fresh install.... I cant stop saying install.......thats now many times ive installed this software🙄
good luck Jedi ... hope it goes ok when you eventually give it a go .. use the force 😉..
any other new features people have noticed asides from voip and other software from the download! section?
Managed to install and overwrite the files, then restarted, but after that, when i started the program it said nokia dongle needed, i then replaced the exe file and the dll with the ones in the crack file. Now it says program has encountered a problem and needs to close. 😞 I don't know what to do anymore. By the way, it has been said you need Diego and Phoenix to flash a phone. What is Diego for? The Reaper doesn't mention anything about Diego.
dunarea wrote:Managed to install and overwrite the files, then restarted, but after that, when i started the program it said nokia dongle needed, i then replaced the exe file and the dll with the ones in the crack file. Now it says program has encountered a problem and needs to close. 😞 I don't know what to do anymore. By the way, it has been said you need Diego and Phoenix to flash a phone. What is Diego for? The Reaper doesn't mention anything about Diego.
yes it does, you have to install diego first then pheonix (dont ask me why)
its all in the reaper instructions
Do you have the lates reaper version ?
cbcharlie wrote:any other new features people have noticed asides from voip and other software from the download! section?
Changes/improvements made MCU SW v 4.0623.0.41 to v 4.0632.0.38:
- Additional applications (market dependent)
- Adobe PDF reader (Already in N80 standard)
- QuickOffice (Already in N80 standard)
- Lifeblog (Already in N80 standard)
- Kodak (Already in N80 standard)
- Search (Already in N80 standard)
- Catalogs (Replaced with Download!)
- Anti-Virus (Already in N80 standard but moved to Download! server)
- Download! (New for Internet Edition)
- Internet Telephone (New for Internet Edition)
- Yahoo GO! (New for Internet Edition)
- Additional Services
- Online Album (market dependent)
- Menu structure
- New "internet" folder created and the following applications are
moved/added to "Internet" folder.
- WEB
- Download!
- Search
- New Support
- HS-69 enhancement is now supported
- Important changes in Video Sharing
- The addition of SIP VoIP means some changes in the SIP
provisioning. The following provisioning information is needed in the
OTA message otherwise Video Sharing will not work:
- Important information when using Backup and restore when moving to the
new Software.
- When restoring a backup image from a previous release of software
the 'Internet' Folder is lost and the applications are moved to the 'My
Own' folder.
- FOTA
- (Pull) is now enabled in most variants
- Audio
- Music Player fails to play .M4A HE-AAC file
- bass boost in equaliser
- Bluetooth
- Improved sniff mode
- fixes audio problems with BT headsets and carkits
- Browser
- Update UA Header for PR2.1
- Browser rendering and wrapping correction for Chinese characters
- Calendar
- Symbian Calendar Interim API does not accept Microsoft's
Recurrence IDs
- Camera
- Improvements in mains frequency compensation in video mode
- Burst mode can take different jpeg quality
- Audio/video missync in recorded video
- Update Noise filter to improve low light handling in still images
- Contacts
- Voice tag issue with phonebook when adding new contacts
- Data
- Phone cannot find other network if you have actived PDP context
- Display
- Correction for miss-read of ASIC version causing pink display
- FOTA
- Camera forward compatibility fix for FOTA update
- Sync agent forward compatibility fix for FOTA update
- UI notifications updated for APAC region
- Gallery
- Change low disk warning to 2.6mb and critical threshold to 600k.
- Gallery crash with slide show and invalid objects
- Icons
- Add new Internet folder icons
- Localisation
- Character conversion methods work incorrectly with some Chinese
characters.
- Memory card
- Error when encountering an unknown media with a password
- Cannot boot up with 2GB miniSD which formatted FAT 16 by PC
- Messaging
- Potential crash when re-connecting to POP3 mailbox
- SMS sending delay
- Potential crash when using always online with IMAP mailbox
- Operator
- Indication of the length of the MNC on a SIM - Requirement based on
EarlyIMS with a SIM reads IMSI from SIM but builds the private identity
with wrong domain
- Refresh notification is not received when EF-subscribed-LAC/CI is
updated on the SIM
- Homezone indication must not be shown during 3G PS
connection/download is active
- Operator naming list updated to version 89
- Call diverts not correctly shown for line1 line2 subscription
- RealPlayer
- Audio Streaming problem in UAE
- SIM
- The SIM Server's fetch control is reset when a refresh is executed
- Startup
- Change default date to 1st Sept 06
- Video Sharing
- Change Video Sharing SIP profile default setting. (See important
notes on Video Sharing at the start of this document)
- UPnP
- Fixes Turning Home network content sharing off forces WLAN
disconnect.
- Fix for UPnP localisation missing strings
- WLAN
- Offline WLAN notification fix
- Registration attempt in weak WLAN fails but WLAN stays up
Needed equipment for software update:
- Phoenix Service Software version 2006.34.2.156 or later
- Product Data Package v15.0
- PKD-1 Dongle & Flash Prommer FPS-10 or
DKU-2 USB Cable
- Product specific service devices
Cash wrote:yes it does, you have to install diego first then pheonix (dont ask me why)
I tried to install Diego but for some reason that also did not install properly. And BB5 reaper said you have to uninstall everything first (including Diego) before installing phoenix.
I must admit that I have noticed a dramatic improvement with the camera in low light....it may be wishfull thinking, can sombody else try taking a few snaps and see what you think ..
Ado Jedi.
Try uninstalling everything nokia related and then run nokia pc suite cleaner
LINK: http://www.nokia.co.uk/A4144912
Go into C drive and check in Documents and Settings (make hidden folders visable in folder options) and delete any nokia/pc suite related folders.
Then do a fresh install of Phoenix making sure the dongle crack is already open and you're ready to hit the install button as soon as required.
Worked for me. Hope this helps.
dunarea wrote:I tried to install Diego but for some reason that also did not install properly. And BB5 reaper said you have to uninstall everything first (including Diego) before installing phoenix.
Uninstall EVERTHING to do with nokia..including diego, pheonic, conectivity drivers...absolutely everything
then get the lates reaper get it here http://www.schwantz-i.org/nokia/BB5%20Reaper-2006.zip zip password: i-ztnawhcs
then follow the instructions, if you cant get the download links in reaper to work, there are alternatives for pheonix and diego in this thread somewhere
install diego
install pheonic then install the dongle crack (quickly)
then restart computer and patch pheonix with the crack
then it should work
Follow the instructions in reaper EXACTLY
Cash wrote:I must admit that I have noticed a dramatic improvement with the camera in low light....it may be wishfull thinking, can sombody else try taking a few snaps and see what you think ..
Same here Cash, loads better now in low light but video is still cack. Wot's your video like now in low light ?
Also cheers for the help setting up Gizmo, now registered but only managed to hear the test message so far as it now says service unavailable😡
micscave wrote:Same here Cash, loads better now in low light but video is still cack. Wot's your video like now in low light ?
No probs 😊
I also noticed if I have Gizmo running on my PC then I cant login on my phone...which is quite bad because it means I have to keep starting and stopping it on my PC everytime I go out.....
Skype for instance is able to run on more than 1 PC at a time...so I hope Gizmo can fix this.....
Looking into Gizmo there are alot of little niggly anoying things things that need to be sorted.
checking video now
yea video is still as sh*t as ever.......but I am happy the photo's are much better now 😉..
Now all Nokia have to do is sort the battery out so that we can have wifi on all day instead of just 1.5 hours and I will be well happy 😊..
Thanks to everyone who's put the advice on this thread, just completed my upgrade to N80 IE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! 😊 😊 😊 😊 😊 😊 😊 😊 😊
juato4 wrote:I CORRECT THE DONWLOAD... PLEASE INFORM OF THE UPGRADES...
This says that the VOIP is able!
Gizmo is able now in ours N80.... i am waiting the EMEA pack with spanish version.. but this have the english.
I would appreciate if some one has link for "How to Upgrade form N80 to N80ie" Step by Step😊
vijushi wrote:I would appreciate if some one has link for "How to Upgrade form N80 to N80ie" Step by Step😊
The BBReaper link further up on this page is a step by step guide really. The only other thing you need to know is further back on this thread. If you're using Phoenix to flash then you should really do the research behind it... it's not really meant for basic users and can give you severe problems if you don't know the full implications for your device.
cbcharlie wrote:voice over ip worked pretty good, gizmo is nice software, the voip is set up nicely, dial as normally, instead of choosing voice call, choose internet call ;]
gizmo install from download folder ok (N80 IE) but can't seem to register to the Gizmo service.
it say "Unable to connect to the connection network". In gizmo troubleshooting this error is for incorect password, but i tried and tried again whit the user and password that work fine with windows client. wlan connection is ok.
dez_borders wrote:The ZIP file is passworded Cash... do you know the password? Can u email please...?
DOH !!!! sorry Dez
Can someone please do i guide whit all links and instructions how i upgrade to N80IE Whant to upgrade to N80IE Scandinavian.
Please!
CuteStoffe wrote:Can someone please do i guide whit all links and instructions how i upgrade to N80IE Whant to upgrade to N80IE Scandinavian.
Please!
If you spend some of your time to read all posts in this thread then you will find that all the information and links and everything else you need is here.....
Read, understand and then do it....
Cash wrote:If you spend some of your time to read all posts in this thread then you will find that all the information and links and everything else you need is here.....
But i dont realy understand..
If u dont want to write a guide just say so.
But it shuld be realy nice fore us dummies
