Does look quite cool, it's an external power supply which you can recharge or run off normal AA batteries.
http://europe.nokia.com/link?cid=EDITORIAL_344303
Although there's no mention of the capacity. Good for emergencies I guess.
On this page it mentions a Power Pack DC-1, but can't find any info on it, looks bigger than the DC-8.
http://europe.nokia.com/link?cid=PLAIN_TEXT_348326
Yeah good if you're travelling
Looks too similar to a Tampax� .. 😮
Lets hope it dont end up in your girlfriends handbag, and god knows where else
More on the DC-1, apparently it's equivilent to 3 950mah batteries, so I guess 2850mah. It also has two leads to power / charge two phones at the same time.
http://www.nokiaphoneblog.com/2007/08/accessory_nokia_power_pack_dc1.html
Apperently the 950 is the total.
From the site -
Unfortunately, Nokia's equivalent of three batteries is a mere 960 mAh - isn't that equal to 1 battery?
Which if true, is just a bit rubbish really.
Edit: This is from the official nokia release (which you linked to in the other thread)
The Nokia Power Pack DC-1 has reserve power in a pretty and portable package, so you can take the equivalent of up to three batteries**
And further down...
**with battery capacity of 950 mAh
So the nokia wording points to you being right, in that its 2850. But then again.... *shrugs*
Yeah I noticed that, but I hope they've got it wrong. This is a quote from the Nokia press release...
Nokia wrote:The Nokia Power Pack DC-1 has reserve power in a pretty and portable package, so you can take the equivalent of up to three batteries****with battery capacity of 950 mAh
Yup!
Although I gather it should be the bigger size, especially being that physical size, you never know with nokias play on words.
If you're looking for an alternate power supply how about a Freeloader?
You can get them from Firebox or from Ebay for about �25. Can't post a link, sorry.
The central battery can be charged by USB or the supplied solar panels and provides a full charge. Also it can charge other things cos it comes with loads of adapters. I've got one cos I spend a lot of time on weekend camping trips and the solar charging is a godsend.
8Ball
8Ball wrote:If you're looking for an alternate power supply how about a...
or the battery from Proporta. Weighing in at 3400mAH it's got enough juice for 3 phone recharges. It comes with attachments to charge itself from car, USB or mains and has a permanent place in my gadget bag.
I'm in the UK, and got a Freeloader. To charge via USB doesnt take too long, maybe a couple of hours. However, solar charging takes quite a lot longer.
In direct sunlight, it would probably be charged in a day. On a window sill, behind glass maybe a couple of days, for a full charge. These are rough guesses though, as it's quite hard to actually time it.
The battery in the Freeloader is just about enough to give the N95 a full charge.
But as has been said is best used for camping etc.
will this batt fir ours
Battery: Nokia Battery (BL-6F) 1200mAH
thats in n95 8gig
It's very unlikely that the 8GB's BL-6F battery will fit in the standard N95 - the back of the 8GB was redesigned (no camera slider, camera is now flush with the rest of the case) thus allowing the larger battery.
