Hi, 😃 😃 8) :P
This Settings should work good with mpegable�s software and SonyEricsson P800.
Total bidrate 200kb
Audio bidrate 16kb
Target framerate 15
Downsampeling (depends on the size of the movie)
AUDIO
Channels Mono
Presision : same as input
Sample rate : 22050
ENCODING
Keyframe period: 75
B-frame : 0
Image Qaulity : smooth motion
Compression Qaulity : Fast encoding
Enjoy Movies on your P800 😃 😃 😃 😃 😃 😃 😊 😊
and where can i get this software ?
you can buy mpegable at Dicas (http//www.dicas.de) The X4 version cost �25 and should do the job.
But the mentioned settings are not good if the MP4 size exeeds the buffer in PV3. I think that about 100-150 Kbps is a lot better - and fast encoding is not really related to the phone but to the pc making the film. Therefore "highest" quality will not impact the performance on the phone, but create better pictures.
Best
Kaz
There is an free aplication called "virtualdub". It has great potential and you can prepare mpeg that will suits perfectly for p800 or any else pda.
how to change the dimesion when using X4? so it can work with the P800
i downloaded the demo of Mpegable X4 but it doesn't have any file extension "mpegablex4Setup". Tried putting on .exe or .zip but invalid. Help!
Downloading from a different location now
http://www.viewcast.com/resource_center/mpegable_download.html
Hopefully it works :P
hi
can this re-encode/convert my existing divx or vcd mpeg-1 or mpeg-2 files to mp4?
What types of video and audio codecs can it support to successfully encode the files to mp4 format?
Thanks.
Could encode with AnasP800 settings using QuickTime Pro. Encoded a 54mb MPEG MTV to a 3.1MB MP4. Played well on my PC but on my P800, it plays for 8secs then and error occured "Could not play movie clip".
What's the problem?
Hey Lazzy
Why r u?
Not.so.Proud.After.all.P800.owner 😞 😞
well you can always mail your P800 to me 😃
:P
AnasP800: what do you mean by "why r u?"
I won't sell it nor give my P800 away at the moment. Will just wait and see whether will there be a fix to the SMS vibrate and ring signal. When i receive an SMS it vibrate like only 3 times but the midi will play the whole damn file even though i'm already reading that message. Weird ...
And the camera picture quality on the preview are looks so pixelised comparing to Nokia7650 with lines and etc. AnasP800, does yours have the same problem? Please share.
when i finish converting files using x4 and send them to my P800 is says wrong dimension!
how can i change the dimension of the movie
thanks
i followed anas' settings, but when I try to play the mp4 on the p800, it says: "unable to play clip". What's up with that? 😞
(I am able to view the file on the pc)
I'm having the same problem with tha cam, the colores are fated and the quality is much lower than Nokia 7650
u can use virtual dub to convert ur movie to any dimentions u want!!
just go to video>filters>add then select resize and u'll see!!
good luck 8)
where can i find virtual club?
and what is the dimension of the P800?
I am using PVauthor move maker !
Its the s/w that the P800 is using as an intergrated video player...!!
Its just a perfect software !! 😃 😃
geovass
and where can i find this program?
[quote="DmX"]geovass
and where can i find this program?[/quote]
I got it from SE Greece...
As i was told it will be inculded in the Multimedia CD-Rom that comes with the phone... :roll:
geovass
I can not find the SW PV author movie maker. It is just not on the CD. Can you mail me the SW? is it big?
could you post it here or could you please send it to me via email? [email protected]
thanks
[quote="DmX"]could you post it here or could you please send it to me via email? [email protected]
thanks[/quote]
Its 7MB...
I cant send it ! 😃
Ask your SE dealer !
They MUST HAVE IT !
thanks[/quote]
Its 7MB...
I cant send it ! 😃
They MUST HAVE IT !
ok post it in any website
please!
Aiyo just use the settings file for mpegable u can download it here:
http://sep800.mine.nu/files/manuals/
But the sound is always off by like 5 seconds. it makes me mad and thus i don't make any movies until the next version of mepegable!
